I Oh and there are quite a few of us that play on rocks... It may just be that you don't know as much as you think you do. I have learned that there is always something to learn!
I stick mainly to Oklahoma malls...
And I see you haven't flipped your 2nd vehicle yet Js93. The three link must be holding up this time around. And does the 93 stand for your birth year buddy, because you sure act your age. "the 6 inch rocks most on here play on"... who says junk like that? Ahh an 18 year old ************. We were all young once. Keep up the arrogant and overconfident banter and see where that takes you though bud
up travel=bad
down traved=good
it should be a 90/10 ratio, if you look at any serious off road rig, they have maybe 2-3inches of up travel,if you have all up travel you get very tipsey on rocks
i am talking about serious crawling, not like the 6 inch rocks most on here play on, up travel sucks, look at alot of buggys, they all have between 2-5 inches of up and all down, it keeps you stable.
If I recall didn't you roll one of you 80's because of poor fab on your 3 link?
Not to be rude but if your fab skills were as good as you say that should not have happened.
You can set your truck up how ever you want, but the travel set up you are talking about is not ideal for an 80, to little up travel on these rigs makes for a poor handling rig especially if you have any weight in the back, you will be bottoming the shocks out and or not use the full range of the suspension travel.
I run 35's and like to be able to stuff that tire up in there with out bottoming the shock.
I run 12 inch travel shocks and do not have bump extension, I put shock bumps on the shock shaft and it works great for me.
I also modified the upper rear shock mount according to how I want my travel set up.
I am no expert, but I to also play in the big rocks like others do here.
Well you can argue hypothetically as much as you like but heres some pics of up travel vs down travel.
14" Shock About 3" of uptravel
Tucks the rear wheel like this
Without shock bottoming out.
Giving this downtravel.
/EndThread
(note old pics are old, 80 looks a little better now)
Also note that yes there are no bump stops in the picture this was taken when getting measurements for the air bumps.
Cool, it's become a picture thread!
I get this compression and extension - sitting around 4.5" up travel right now, would like to tweak it a bit for another inch of up travel in the rear - too much bumpstop needed for clearing the 37's w/ long travel shocks.
Have you modified your rear upper shock mounts yet?
I messed with mine for a while until I got them to wher I wanted them to be after making a new mount bracket. It is still not perfect but it works.
I went with diy shock shaft bump stops i made and they work out for me.
I noticed that to, unless he is dropping that bumpstop 5-6 inches he using his shock as a bumpstop.
Does not look like the ideal set up to me, but to each their own, it is a nice rig though.
Do those shocks have a built in bumpstop? I can't tell from the photo, or from the Fox website
