Please read my story and help see if you have any advice on the problems im having (related to the vehicle)
Some of you have have read my build thread for the v8 swap. That was just the begining of a long road.
Since the swap runs as oem as can be, im doing my best to sort out problems. Power window motors, lockers, leaks etc.
When I got the rig it started off with - 315/75/16 MTR's that were about 50% tread but cupped and worn wrong. It had a 2.5" OME lift with the OME caster bushings and some type of home brew welded washer on the lower front control arm to increase the caster further.
The rig seemed to drive ok, but as time went on I wanted to start getting it to drive more like a maintained vehicle than a jalopy.
The front hub nuts were loose and the spindles were damaged from that. So I replaced the spindles, hubs, bearings/races, calipers, pads and rotors since the majority of that stuff was trashed.
I also did rotors, pads and calipers in the rear at the same time.
The beast drove much better but there was still a slight shimmy and as the months ran by, the tires became more chewed up.
At this point I was holding off on a tire purchase because I didnt want to throw money out the door if I couldnt narrow down the problem.
I decided that the oem bushings may have been shot so I ordered up the full set of bushes from ebay austrailia. What a pita it was to do that job. Took a full day for the entire rig setup.
That fixed a little more of the shimmy but as time went on I still wasnt fully satisfied.
Goodyear was having an $80 rebate if you bought 4 315/75/16 MTR Kevlars so I shoped the priced and pulled the trigger. Got them mounted up two weekends ago in hopes that it would fix the remaining problems I was having. Big negative on that. WTF Over.
At this point im pissed off and worried that im going to destrooy $1,400 worth of tires... and the only thing I hadnt done was rear wheel bearings. So I did those. The old ones were worn quite a bit and I got a little more of the vibration out. Now im passed being pissed and just frustrated
Now before you think drivelines, its not a driveline vibration im feeling. Its in the tires for certain. And it was causing cupping and shredding of the tires which im fairly certain wouldnt be caused by drivelines.
I had been bothered with the fact that the axles werent dead center so I decided I would get the slee panhard adjusters.
I figured WTF, since im throwing money at the fawker cause I daily drive it and want it to run totally sweet, lets throw some trunion bearings, front kuckle rebuild kit and tie rod ends at it.
Then the rig will ostensibly be brand new under the frame.
I installed all that stuff on saturday and took it for a ride, boy was it smooth as silk. At 70mph on the freeway it felt like my wifes lexus, but darted around a bit. So im thinking fawk yea finally some major headway. Time for a lifetime alignment from firestone.
Get that biotch in for an alignment sunday morning first thing. Got it back, holy sh1t it darts around even more now. Called them up yesterday, explained the situation. Brought it back to them last night, worked with the tech to put a little more toe back into it, and road tested it three different times. Still darts around a bit. Thier lead tech is thinking worn steering box.
When we move the steering wheel, the pitman arm moves right away.
Where to go from here ? Make some small adjustments to the steering box maybe ?
Please advise (and no I wont be giving the beast away due to frustration. Ill just be keeping it longer once I get it figured out
