removing the swaybars altogether definely provide more flex, quite a lot actually, but also means alot more body roll at hwy speeds, enough body roll that my girlfriend complained.
I made a simple disconnect for my 80 series that cost maybe 20 bucks.
I thought about taking pictures and doing a thread with details but got lazy...
here is what I did, if you need more info let me know, I could take some pics I guess
REAR
1)remove bolt & nut that connects the sway bar to frame post (not sure of correct part name, when I say frame post I mean the vertical tubular post) Insert a baled linch pin (D style) or snapper pin will work also instead of the bolts and nuts.
2) back off the nut that holds the frame post in situ. Place post in vice or drill press, thread nut onto post, drill small hole (3/16") near *middle of threads. Back off nut now to remove any burrs from drilling and ensure proper thread alignment. Insert post back onto truck with 1/8" hairpin cotter pin.
*proper location of hole must be determined so sway bar is not sloppy, measure two or three times before drilling
Now to disconnect rear sway bar jump out of truck, remove two baled linch pins & two hairpins, **fasten sway bar to frame, put two tubular posts in your door panel.
FRONT (easier than rear)
1)remove bolt & nut that connects the sway bar to the axle. Insert a baled linch pin (D style) or snapper pin will work also instead of the bolts and nuts.
2) fasten sway bay up to frame out of way.
Now to disconnect front sway bar jump out of truck, remove two baled linch pins, fasten sway bar to frame & now drink your beer
notes:
1. to undo and reconnect sway bar the truck needs to be sitting level or close to it, otherwise the bushings apply too much pressure for the pins to be removed by hand/ I always try to remove on pavement.
2.I use a velcro straps to fasten the sway bars up to the frame but bunjys or strech cords could also be used.
3.I carry spare linch pins and hair pins just in case.
4. do not leave the linch pins and bushings on the sway bar when you disconnect, remove them and keep in the truck.
*************THIS IS A WARNING. ***************
** even though rear sway bar is sitting in horizontal position it is possible for it to rotate and jamb into ground esentially picking up the rear end of the truck. sway bar must be secured to frame.
I learned the hard way behind Harrison lake, all of a sudden a large noise from the rear end and the back end of the truck lifted 12" in the air. After I stopped to inspect there were two drag marks in the logging road for 30 feet and the sway bar had rotated all the way around behind the axles. there was now so much pressure on the swaybar mounts on the axle i could not undo the bolts. In order to extricate my self I had to drrive 100 more feet to a ditch (while dragging the sway bar) and bury the nose of the truck deep which took enough presure off the sway bar to allow me to unbolt it. believe it or not the sway bar was ok but the mounts on the axle were poached. Luckily a short while later this truck was written off by a kid in a pathfinder (all his fault) & I found another 80 series. So I did the same disconnect and it works really well. (now that I secure the sway bar to the frame
let me know...
