As we all know, the 80's front end simply doesn't have much flex to it. At all.
My truck:
I ramped my truck to measure how much compression I could get in my shocks. I was able to fully compress the rear....but the front laughed at my attempts to compress it.
Many of us know and use (myself included, though I did not in that pic) the "poor man's three link" AKA "hitch pin mod." And while that does add a bit more suppleness to the front, and allow it to flex a bit more, the body still wants to follow the front axle and make the rear do all the work.
So I've been bouncing around different ideas, and in all my research the one that's appealed to me the most is the X-Link.
Now this isn't exactly an apples-to-apples comparison, as he's running about a 6-7" lift and also has his radius arms flipped, but the big thing to look at is how flat his body is. (That and 38" tires dropping below the door sills front and rear.
So a few days ago I went
had a series of
on how to do this as a complete bolt on mod. I had always gotten hung up on several parts requiring welding, which tends to scare (some) folks off.
It would require cutting/grinding off your front axle mounts for your control arms, but other than that it'd be a complete bolt on mod.
Some advantages I can think of:
Some disadvantages I can think of:
So I got two questions for ya.
My truck:
had a series of
on how to do this as a complete bolt on mod. I had always gotten hung up on several parts requiring welding, which tends to scare (some) folks off.It would require cutting/grinding off your front axle mounts for your control arms, but other than that it'd be a complete bolt on mod.
- Most flex possible (yes yes, I know you'll have binding, but it would allow the front to cycle much more than it does). Will have most of the advantages and handle similar to a 3 Link on the trail.
- Completely bolt on.
- Easily adjustable caster.
- When pinned in place, will drive and handle identical to OEM.
- Does not address the binding that can happen when fully flexed.
- Requires cutting/grinding off the front mounts.
- Fairly hefty hunk of steel hanging off the front end. (Advantage as it'd take a hit from a rock before the axle housing? Great for snow plowing too!
) - Cost? (Ya'll are a bunch of cheap
) I have a rough idea of price to make a one-off, but no idea on price for a production run.
- Would you be interested?
- What sort of price range do you think would be reasonable? (In other words, how much of your
$$$ are you willing to give up?)
to spend the money to do so.....
