My point was in post#4 was to not assume that just because hoses look good, doesn't mean they are good. When you pull hoses off, it's the perfect opportunity to check out hose condition, connections, passages, clamps and backflush the whole system. There is no way to predict failure, you can only use good judgment and experience and be a pessimist. When in doubt, replace. And use distilled or at least filtered water to mix with the coolant.
where is this located in the bay?
Actually, this is an excellent graphic example why you should be draining and flushing your coolant system every other year at minimum. The coolant turns into a substance that can attack a lot of materials. So don't neglect!!
DougM
All hoses were replaced (including PHH), although a few years ago already. Heater valve looked fine at the time.
Part number is 87240-60140 and is available from your favorite CPartsMan.
Good news is, it takes less than an hour to replace and I didn't drain an ounce of coolant. Just remove actuator cable, loosen the hose clamps, remove mounting bolts, keep the valve closed, pull off left side and insert in new valve, then right side, slightly snug clamps, attach mounting bolts, re-adjust clamps, attach cable and Bob's your uncle. Make sure to properly adjust cable so closed is closed and open is open.
