ok,
so as some of you may know i have had low oil pressure light problems intermittently with my 22re (88 4runner).
see "engine oil viscosity" thread
so, the next step was to get the oil pan off and inspect the rod bearings and pickup tube gasket. here is what i found.
pickup tube gasket was there, but i dont know if it was functioning properly. it was kind of loose.
Next is thrust clearence. Used magnetic base dial indicator with .0005" divisinos.
Allowable standard Thrust clearence for rod bearings is .006"-.010".
Cylinder 1: .0085"
Cylinder 2: .008"
Cylinder 3: .009"
Cylinder 4: .007"
So pretty good there. would feel okay leaving that for a while.
Next is radial clearence. Disassembled each cap individually, cleaned, dried, and recleaned. assembled and torqued with plastigauge. Here are the results.
Allowable Bearing clearence standard .001"-.0022"
Cylinder 1: .0025"
Cylinder 2: .002"
Cylinder 3: .002"
Cylinder 4: .002"-.003" (varied largely across bearing to scarring)
So they are right at or over the service limit.
Additionally, I found 3-5 pencil eraser sized pieces of the plastic timing chain guides in the oil pan. As well as 15-20 large scraped off pieces of bearing.
AND, the icing on the cake, while rotating my crank to acess different rod bearing caps, i was greeted with the sweet sound of gurgluing and the frequent shower of ...you guessed it antifreeze from the top of the pistons. so, i guess i found the early onset of a head gasket leak as well (no signs in oil yet..stll black)
I am borrowing a video scope from a neighbor this week and will be taking a better peek at the timing chain condition before making my final decision.
But in your opinions would you take the time and money and completely rebuild this motor, or go for a remanufactured motor with a warranty. Quick online estimates for rebuild parts will be about $600. not including machining work and/ labor.
On the other hand, As an example LC engineering has a street remanufactured motor with new everything, 3 year unlimited mile warranty for $1900. all i need is intake, exhaust and wiring.
Post your reccomendations and why.
sorry for the long post.
Cylinder 1: .0085"
Cylinder 2: .008"
Cylinder 3: .009"
Cylinder 4: .007"
Cylinder 1: .0025"
Cylinder 2: .002"
Cylinder 3: .002"
