what can i put in this spot??
in the nappy dugout
since my radio is in the Tuffy what can i put in this spot? Is there some insert that fits without modifying it a ton??
How about an oil pressure and water temp gauge
-CB? maybe you have one elsewhere.
-Guages
-Aftermarket Inclinometer
-Locker Switches
-Light switches
-Tuner for you diesel conversion...
OEM radio. My theory is that tweakers will laugh and walk on by. My Jensen heavy duty is in the tuffy, and I kept my OEM in that spot.
Ex
look for GS-UR T-3 Radio Gauge Panel from Glow Shift, 3 gauge DIN panel. I'm in process of doing the same... 2 1/16th size, for 3 gauges.
I'll post up a pic later...I'm about half-way done. When I say it fits...you just have to make it work... no cutting but I've used some zip ties to secure it to the old radio brackets.
yeah, i searched but couldnt find it. Pics would be great.
the bad thing is i think all the radio brackets have been cut out :(
If your willing to cut into the dash, you can fit the inclometer from early 4 runners.
