I found that picture above, too, with a search. Here's another one of mine. The view is the side of the carburetor facing the firewall. Please ignore the red and yellow arrows. The barrel on the choke cable fits into the hole circled in green. The end of the housing is secured in the clamp using the screw indicated by the green arrow. The cable approximately follows the path of the green line. You will need slack in the cable to get the barrel into the hole. I gently bend the barrel almost back onto the cable to get the barrel into the hole and the cable through the slot. This is easiest done with the coke knob pushed in and the housing not clamped. After the barrel is secured, then you clamp the end of the housing using the screw.
