BlueCruiser84
SILVER Star
I had another thread with a couple questions in it, but I figured I would post up a thread following just the spring over. I'll try to be thorough, but, as I am finding out, it is very easy to skip over steps when I am doing the writeup, so please feel free to ask me any questions you might have.
This spring over is being performed on the truck in my sig... A 1984 fj60 with a 2f on BDS 2.5 inch lift springs.
**********THIS IS HOW I DID IT, NOT HOW IT MUST BE DONE. The best thing about a spring over is deciding how you want to tackle the job. Use the threads as a guide, but remember that every truck is different.
I started with freeing the front axle and removing it from under the vehicle. This consists of removing the u-bolts, steering, front or rear shackle/spring hanger, brake line (from frame to axle), swaybar (if it's still hooked up), driveshaft, steering stabilizer, axle breather, and lower shock mounts.
I used a pickle fork to remove the drag link from the pitman arm as well as the tie rod from the steering arm. It worked.... but I'm not sure if I did something wrong or if the end of the drag lik was just so seized into the pitman arm that it decided to come apart this way. I'm not too concerned because the end was shot and I am replacing it with high steer, but I was just curious.
Here is the front axle out of the vehicle with everything still attached. I was planning on putting it on the work bench, but when it came to choosing between blowing out my lower back trying to lift that housing or having to work on the floor I decided to stay nice and low.
