If I could get some help it would be much appreciated. A while back I smelled fuel leaking out somewhere, I found the problem and thought i had fixed it. Behind the passengers seat of the 77 is a black plastic object the looks like it would mix some gases, it has 3 lines going into one chamber and has an output piece that has been capped. Well the male piece had snapped off where it connects to the chamber and i used some jb weld and some electrical tape to provide a cheap fix, Well that didnt hold and it broke again. Should i order a whole new part or try to do another cheap fix. And I feel as if the chamber should be pushing the fumes through the piece that has been capped, am i right to think this?
