Who do I get in touch with to send my speedo housing off to to get milled out so that I can put two seals in it?
Is this really worth the trouble?
Agreed. if the PB drum is grooved, a $30 speedi sleeve solves the issue. If there is play in the bearing preload, neither solves the issue.
So, check the output shaft for play(even a tiny bit will allow the seal to leak) or a groove worn in the drum seal surface. correct either problem, and dont forget to put some permatex on the washer /nut that hold the drum on.
I have never needed to put the double seal on a cruiser... correcting underlying issues solved the problem.
What does the permatex do?
Is that threadlock?
The interal rib the housing can be removed with a die grinder in less time than it takes to find a box to ship it in. I thought we discuss this on the phone. I'll be happy to do this for you don't have tools/comfortable with it.
Gotta get that output bearing shimmed correctly first.
mudrak does the double seal setup and yes, it is totally worth it. i was doing seals on my 68 every year before going with the double seal setup. never did one after that. no leaks (at least from there)
Yes he does, and Poser does too.I have used these from both sources, and have been satisfied with both. I will no longer rebuild a pre-81 t-case in my shop without at least suggesting one to the customer.
Best
Mark A.
