Thought I was making pretty good progress, running / head lights working good (with the exception of no park lights - only full lights but I'm pretty sure that is my old switch I'll deal with later). I am trying to hook up the turn signals and bypass hazard lights completely.
From the stock turn signal switch, I have two GY, two GO, a GW, and a G green (wiring schematic I found from Coolermans site says that should be GL - green blue but I'm assuming my green is green blue).
The painless harness provides the right and left rear, right and left front, a power wire and a brake light wire. So I have both right front and rear connected to one green yellow and the left front and rear connected to green orange. The G is connected to power source from Painless (purple wire) and GW is connected to white brake switch wire from Painless. When I engage turn signal all lights flash including headlights. I tried wiring front and rear separate to each of the individual GO / GY wires but it had no effect. Also tried several variations and a few hours with multimeter to no avail.
I also have a brown emerency flasher B+ wire provided in painless kit. Not sure where to put that or to dead end it.
Any suggestions as to how I can bypass having a hazard switch (can I?) and if so what am I missing. What would make all lights including headlights flash?
To review the headlight switch hookup, I again don't seem to have stock color wires. Coming out of what appears to be my stock light switch, i have R, RW, and two Green. The two green are not hooked to anything with red being power source from painless kit and the RW hooked to park lights and dimmer wire. Also tried multiple variations in that setup with no success other than as wired.
Thanks for any input.
