I'm doing a rebuild of the 1970 forty series, and I've torn the axle apart to do a minitruck disk swap. Anyways, I've been dreading pulling the axles apart to do the swap out. I got the axles apart pretty quick with the pipe method. No real problems there.
After cleaning out the Birfs and removing the axle snap ring parts, I fooled around with getting the 40 inner with the minitruck birf. I read Guppy's post about using screw drivers and a helper with a BFH. I wanted to try to get 'em back together on my own so I tried a few things-- none worked. I went in & ate, then thunk for awhile.
I decided to try squeezing the outer ring with a piece of plastic tube & a hose clamp. It worked like a charm. The hardest part was to align the birf ontop of the axle correctly.
What I did was find a piece of plastic 1.5" pipe, cut it to a width of about 2cm, took a piece out so it'd squeeze the snap ring & stuck a hose clamp over it. I lined it up & also moved the inner snap ring down so it have room to move when I pushed the birf down on it.
I put the birf on the axle and whacked it with my trusty oak 2x4. I had to readjust the plastic clamp the first time I tried it as the snap ring didn't seat right. Anyways, the only problem I had is that sometimes you'll move the birf down too far and you have to seat the second, larger snap ring back up & check it so the inner axle and the birf are solidly connected.
The toyota part numbers for the two are 90520-28036 for the larger snap ring and 90520-27091 for the birf's snap ring.
Hope this helps someone out.
Here's the axles test installed after grinding the axle housing.
ty
ty
