I've had a York based On Board Air setup on my 40 with a small block Chevy for several years now and when I changed motors I had to make some significant changes to accommodate the new Serpentine Belt setup so here goes...
What I started with...
The York compressor was attached to the drivers side of the motor using a custom slotted (read: adjustable) bracket that a buddy had made at his motorcycle shop. I had mocked one up with cardboard and he plasma'd and welded it in about 15 minutes. The right tools make all the difference. It would have taken me 2 days and it would have been FUBARed. The mount bolts to the front of the head and ran off the power steering pulley. All the plumbing was along the drivers inner fenderwell and ran to a 5 gallon tank under the rear of the truck that then dispersed to three air fittings. One at the rear and one each near the kick vents in front of the doors.
Going to the Serpentine setup was no small task. For one the alternator was now where I used to have my compressor so the compressor would have to be switched to the other side...
The issues at hand were:
1. I needed a serpentine pulley on the York (to replace the V-Belt pulley).
2. I needed a new bracket that would mount to the A/C location on the Ramjet (located on the passenger side rather than the drivers side).
3. I needed to move one battery from the passenger side to the drivers side (along with making new battery cables to fit).
4. I had to reroute the air lines to the passenger side.
5. And Re-wire the compressor and valve to the passenger side.
6. I would also need a new 105" Serpentine Belt.
I turned to the resource I had used when I first set up my system many years before: Kilby Enterprises
