Steering is way crazy. thinking of getting CCOT tie rod kit. Anyone have any experience with it? Would that be the best place to start?
thanks
thanks
check your center arm...that's usually where the play is the worst. have someone wiggle the wheel and see if it is sloppy. fairly easy rebuild
Heh. Same here...
Also, how do you "tighten" the link from the pitman arm to the relay rod? Its got a weird connection I've never seen before.
If you still have the stock steering box you can take a lot of the play out by adjusting the manual box. The adjustment is on the inside towards the motor. You can take all of the play out of the steering wheel if it's not worn out.
If you still have the stock steering box you can take a lot of the play out by adjusting the manual box. The adjustment is on the inside towards the motor. Loosen the nut and screw in the bolt (with a flat edge screwdriver or a coin if clearance is tight). You can take all of the play out of the steering wheel if it's not worn out.
Later,
Later,
Drag link end?
Take out the cotter and tighten with a screwdriver in the slot.
