Build Zeke, the 1975 Wanderer and DD
Member Build Threads
As it stands, on level ground, I measured a 6 degree negative caster using the flat of the steering arm on top of the birfield joint. If I understand what I'm measuring, and if the four bolts on top of and the bottom of the hub are perpendicular to the pivot line of the steering.
Additionally, the third member is tilted forward 10 degrees, but I don't know what that has to do with anything. But I bet if you knew the stock angles, you could tell how much the PO had it turned when it was cut.
Or is that positive caster? Looking from the inside of the wheel, the Kingpin axis is leaning BACK.
Stole this from another post. Yes, Virginia, it's 6 degrees POSITIVE caster.
I’m about 5 hours from you. I could probably part with one of my SUA front ends. Could possibly do a road trip down to deliver it. Need to meet up with MudDauber from Atlanta to deliver his 8274 in the near future. Just an idea. I recently bought new stock steel wheels from local dealer. Four of them were around $500.
Bill da Man 🤔😉👍
Your best bet is to swap the housing. Having the wrong caster will make the steering feel wrong and it won't return to center naturally. There is a noticeable difference driving a truck where the castor is incorrect.
What's the rear housing look like? Did they cut the perches and weld them on top? That will need to be reversed as well or swap in a fresh housing.
I agree with @tucker74 you should be able to get away with new bushings and u-bolts.
The rear housing has two sets of shock mounts, top and bottom, and the perches are welded on top.
I'll obviously have to cut those and put them back on the bottom where they belong. Will get bushings and u-bolts ordered, as well as new wheels, shocks and tires.
I've found heavy duty Monroe shocks specifically built for the FJ55 fronts on Rock Auto. Doing a bit of research showed that the rears are pretty easy to find as they are basically FJ40s, but the fronts are weird.
Wheels will be OEM from McGeorge Toyota at $125 a pop. I had no idea they were a) still available, and b) so reasonably priced.
Still thinking on tires. I'm going to make my tire selection reveal when I get everything back to stock configuration.
My wheels here in Missouri were discounted 5% because I bought 4. Might ask them?
Here are the ones from my stock 73. They are 1/2” diameter, hope this helps.
All the places I could find advertise rear u-bolts. Are the fronts different somehow?
I'm looking at the front right U-bolt nearest to the pumpkin, and it looks much bigger than the rest.
(Edited to add: I'm just going to wait until I have the front housing in hand and then get U-bolts to fit.
I don't think you will be doing a lot of off road but it might be a good time to get the u-bolt flip kit that puts the bolts on top.
Spent some quality time today with Zeke, my dog Lela and the Land Between the Lakes National park. It's a great place to off road 40 min from my house, and this is the first time I took my pig out there to play. There is a designated ORV area but the trails throughout the park are actually cooler.
