I know there’s 1000 threads on vacuum and I think I’ve read them all, but here’s my question. I’ve got a 79 pig with a Weber 38. I recently replaced the coil/dizzy with the Redline cruisers kit. Timing is set to 9 degrees and idle is 700rpm. I only have 3” of vacuum off the carb port, which increases to 20” with throttle. I have 20” of vacuum at an intake port which is capped. All the readings are steady. If I run a vacuum line to the dizzy advance from the intake port, I see no difference in driving performance than I do coming off the carb port. I’ve hosed the base of the carb and the spacer plates with carb cleaner and got no change in idle, so I don’t think there’s a leak there. Why do I have almost no vacuum through the Weber? Can that port be plugged and it needs to be cleaned out?
