Hey all,
1999 LC with 220k. Mostly stock Alabama car with the last 8 years in Virginia Beach
I have watched the brake failure threads with very closely but have not seen this particular issue come up.
My daughter reported that her brakes "failed" resulting in a minor fender bender a couple months back. I was skeptical as a typical father is, but put the car through a pretty rigorous set of tests and the brakes performed wonderfully. It has been DD'd from then till now, and today she called to say that she had been pulling up to a light and the brake pedal was hard, but not effective. She was able to get stopped via strong legs, and then pulled off into a parking lot. There was not a brake alarm or dash light in either case.
I drove it home today and it drove just fine. I pumped the pedal to failure with the key off and upon starting, the pump ran smooth and quiet for ~20 sec. I application of the brakes=no action. Holding brakes=no action. 3 subsequent pumps and the motor ran for 3-4 seconds. Subsequent testing revealed that the third distinct application of the brakes with a full release in between always triggers the pump, and motor always runs smooth and quiet.
So, my question is, what else should I look at? I am easily able to rebuild the MC, but it does not appear to need it. Any issue on the pump/motor/accumulator side should be accompanied by the warning light and buzzer, so that shouldn't be the issue (verified both light and alarm work). I am planning on a full flush/bleed of the system including the abs pump, but wanted to check in here to see if the gurus had any tips.
Thanks!
Dan
Thanks!
Dan
