Year differences in TPMS transmitters. (2 Viewers)
Minnesota, Wisconsin out my window.
Two weeks ago I bought a set of four 2016 wheels with snow tires and TPMS transmitters to use on my 2013 LC. Immediately after swapping the tires/wheels LC TPMS threw an error code and lit the dash warning light. Obviously it was because the computer didn’t know the id’s of the new wheel transmitters.
I borrowed a TPMS reader, scanned the transmitters, and inputted the five transmitters id’s (four from the 2016 wheels, one from a 2013 wheel) via Carista. I thought this would solve the dash light issue. It didn’t.
I bought a Autel MaxiTPMS TS501 reader for $230 thinking I’d solve the issue with a more capable tool. It will read all the 2016 tpms transmitters when set for a 01/2016-12/2018 LC, but then won’t recognize the 2013 transmitters. It’ll read the 2013 tpms transmitters when set for a 01/2006-12/2014 LC, but then it won’t recognize any of the the 2016 transmitters. There is a difference between 2013 and 2016 tpms transmitters. They can’t be mixed. Buying the tool was a bust for this situation.
Yesterday I bought a set of five Falken Wildpeak tires at Discount Tire. I asked them to mount the five new tires on my five 2013 wheels and reprogram the TPMS. Those five wheels had been on the LC until just two weeks earlier. After mounting, the tech came back saying that several of my 2013 transmitters were bad. The guy scanned them with his tool, showing me they were bad. It’d only recognize two of the five transmitters. Knowing they were working only two weeks earlier, I figured the tech had crunched them when he removed/replaced the tires. I was offered to buy five transmitters at $60 each to solve the problem. I wasn’t real happy. I took out my Autel TS501 and read all five 2013 transmitters, hooked it to the OBDII port, inputted the transmitters id’s, and put out the warning light. All he said was that your receiver must be more sensitive than ours. He has a bad tool. My transmitters are fine. The tpms reader reports battery strength. My were all reported as ‘good’ by my reader. I wonder how many others have bought new transmitters based off of a defective reader?
The takeaway? 2013 and 2016 Toyota TPMS transmitters don’t mix and my $240 reader saved me spending +$300 at Discount Tire.
I just found out the hard way that the 2015 and below TPMS sensor doesn't work at least on the 2019. I was doing my research and saw that the Denso/Pacific 5500105 PMV-C010 sensors from my 2015 Highlander were the same part # on a 2018 LC according to Rock Auto. They don't list anything yet for the 2019 but to my knowledge, there's no difference between a 2018 and 2019 so I assumed that they work on the 2019. Got my RW Wheels installed, programmed the LC with the sensor IDs but my tpms dash light won't turn off.
I had time last night so I uninstalled the sensors on my original 18" wheels and lo and behold, they have a different part # PMV-C015. I'm going to swap them out later today and have to re-program the old IDs back.
I had time last night so I uninstalled the sensors on my original 18" wheels and lo and behold, they have a different part # PMV-C015. I'm going to swap them out later today and have to re-program the old IDs back.View attachment 1996771
Toyota's current Part Number for the TPMS Sensor up to and including MY2015 is 42607-33012. This replaces Part Numbers 42607-52010, 42607-52030, 42607-33010, 42607-33011, 42607-34020, and 42607-35010.
Toyota's current Part Number for the TPMS Sensor for MY2016 - MY2018 (and I assume MY2019) is 42607-48010.
HTH
HTH
Yup, MY2016-MY2019 is 42607-48010 or DENSO 5500106
Just bumping this to say thanks @jeproks . Tried to program the sensors when I installed the Rock Warriors that had been on my 2011 LC on my 16 and they would not program.
Advance Auto, Denso and the Rock Auto site both show the wrong sensor as compatible with my 2016 (5500105 PMV-C010).
I confirmed the PMV-C015 is the correct sensor after cross-referencing the OEM # and seeing this thread. This should save me some headaches swapping in and out the wrong sensors.
I am going to have a set of 5 Denso 550-0103 from my 2011 available in about a week. Bought from Rock Auto and installed a year ago (have receipt) if anyone needs a set.
Off topic-I have to say, IMO, the Rock Warriors look so much better than the TRD pro wheels!
HTH
To add for future reference - same Toyota part # for the 2020 models.
I bought TPMS sensors from Rock Auto for my 2018 LX and they sent the older 5500105 PMV-C010 sensor.
I took it to the dealer to get installed and balanced in my new heritage wheels and wasted hours and hours to find out they were the wrong sensors.
Rock auto's database is wrong and I told them and they are taking them back and giving me a refund at least. At first they wanted me to pay return shipping until I finally convinced them it was a problem on their side not me ordering the wrong ones.
You're better off than I was. Rock Auto refused to replace the TPMS sensors I bought from them, based on the same bad information a year ago. They said that they got the fitment information from Denso, so I was wrong and to bugger off.
Please Post photos. Sounds like a great combination
