In middle of rebuild and have question about the roller bearings that go on the output shaft for the high and low gears. Do rebuild kits typically come with replacements? I can’t seem to find new ones with my kit. TIA!
Early transfer cases used roller bearings. Later cases don’t use rollers. You may have the wrong kit.In middle of rebuild and have question about the roller bearings that go on the output shaft for the high and low gears. Do rebuild kits typically come with replacements? I can’t seem to find new ones with my kit. TIA!
Get in touch with @cruiseroutfit and they can help you out with what you will/do need.In middle of rebuild and have question about the roller bearings that go on the output shaft for the high and low gears. Do rebuild kits typically come with replacements? I can’t seem to find new ones with my kit. TIA!
