Lil'John said:does anyone feel there is a risk in driving it?
LilJohn, dont drive it. I still suspect your center-pin. Have you dropped the axle on the D/S to see if its broken? I noticed in the picture with the Jackstand under the leaf spring it looks like your U-bolts are tilted forward. I also noticed that the U-bolts dont look like they go through the u bolt nuts are they too short?
Thanks Bob.
Pictures will be coming.
Yes, the spring hanger is separating enough that I can see the rivet between the frame and bracket at the front edge. The frame is stretched around the rivet.
