Wanted Wtb. HJ60/HJ61 auto trans (3 Viewers)
I have an A440 from a 3F, is there a difference between a 3F series gas and H diesel A440?
Wasn't sure, I knew the B series diesel A440 was different, but I thought the H series were the same.
Scott
yes they are different. thanks for posting
What is the difference?
I know the bellhousing on the diesel will have the tach pickup hole, but what else?
Phil
Phil
bellhousing is different bolt pattern, torque converter is different externally on the engine side, torque converter has different stall speed, valve body in trans is different
the main case and gearing is the same
I have one, it's already out with the t-case removed
fluid color is good and the test drive went fine
I am picking a transmission and t case next week. I need the t case I was told it all works great. I will let you know condition on the auto tranny if you like.
do you have the torque converter as well? How much? Thanks
