- Thread starter
- #21
Fusible Link: Aka, smaller wires part of the + battery terminal. When I checked, I put the + on the bolt downstream from the fusible link & - on neg of battery. If they were bad, I should have 0 volts or open circuit.
Brass screw: I'll check tonight after work.
Meter: Its a CEN-TECH Digital Multimeter. I don't trust the ohm readings on it. Seems the volts are fine.
Sensor in engine compartment: A likely suspect: I remember pulling something out near the Air Sensor (MAF or AFM). It had a bunch of delicate tinfoil looking stuff. I carefully put it back in and disconected something else to get that part off. I'm trying to remember. I'll look closer tonight. I'll be I screwed up something here.
EB1: I'll look at the fuse box per your description. It doesn't sound like I had to remove it and I don't remember disconnecting anything near the fuse box. There were the EGR connectors, then another connector or 2 that were line-to-line connectors near the EGR connectors.
More troubleshooting tonight. Thanks for the help.
