- Thread starter
- #21
PART SEVEN: The Rope
Now it was time for the winch line. I knew I didn't want the steel cable. There are plenty of discussions of synthetic rope vs. steel line and there is no point discussing it here. Synthetic was the only option for this project. For this install it was Yankum Ropes' synthetic rope instead of using Warn. Why? Because they are local to me and made in the USA. More to come from Yankum Ropes and Wits' End.The decision was made to go 7/16" rope vs 3/8" @100ft. Why go the thicker rope? Because it was stronger and it fit my drum. Simple as that.
The winch rope itself doesn't come with a lug. Turns out that decision was made because there were so many mounting options available. Could have done clevis knot or duct tape or crimped on a battery lug. Ultimately we decided to go our own route because although the battery lug made the most sense, we wanted something more malleable that could be shaped to the drum. As it turns out there was some copper pipe handy that fit around the rope perfectly. Tried crimping it first but that wasn't ideal. So we moved to instead use the press to shape the copper flat after drilling a mounting hole thru the copper. Worked great.
Now that it was in the shape we wanted AND the copper was pre-drilled, it was time to get the hole into the rope so that the bolt would go thru. Easy fix, used a soldering iron and melted the hole into place. This also prevents the rope from unraveling.
Now the rope can be slide thru the RED WINCH PLASMA LOCK to literally lock the first ten loops of the winch into place AND screw the bolt into the drum. This rope will NEVER come undone. Its secure for sure without gumming up the rope with duct tape.
Once the rope was taught enough, the copper lug was "suggested" into place using a dowel and a hammer to form it to the drum. Came out awesome. The first spool up was done by hand and not under load. The second spool in was done under load. This is when a huge problem was noticed...
But first we had to notice how bad ass it was all starting to come together...
hahaha
