Boy, is that ever some ironic projection.you feel your standing in the forum is being threatened
Mine just had its 30th birthday. It is still running the original links.![]()
I was referring to my car having had the FL's removed and fitted a fuse box despite my 80 not having any failures, my comment was based on experience of working on customer's 80's who have had the FL's fail NOT ON MY CAR,.
Dave
Mine failed a few months ago. But it's only 25 years old.Mine just had its 30th birthday. It is still running the original links.![]()
I find it fascinating that I have a comprehension problem because I didn’t realize that you were referencing a non Toyota 80 series when stating that you had experienced many failures with fusible links.
I don’t think I’m alone in that, here in the 80 series forum, unless it’s stated that you are referencing another vehicle it is assumed you are referencing your 80 series Toyota.
Knowing at anytime you could be referencing any and all manufacturers of vehicles kind of undermines the value of your claimed experiences.
Best of luck with your recovery.
My experience with fusible links is that they are not likely to fail unless there is a fault in the electrical system. I’ve seen that once with someone else’s truck on a trail run. He had a bad engine harness.I also note you keep harping on about my experience, I have told you of mine, and you have not mentioned yours....not that it is my business, but I use it to back up statements I have made, this stops people thinking I am talking out of my arse as many do.
I can’t remember saying anything against you modifying your fuse box. But if you would be so kind to quote my passages where I did I would appreciate that.with your inability to answer and explain what you have against getting rid of the FL's and fitting a fuse box instead is somewhat disappointing, but I think I may have covered that a little later?
Me too, but I was gonna blame @TRAIL TAILORI ordered 2 last october when I only needed 1. You all can blame me for the shortage.
I order 10-50 at a time from Japan. Blame me if you want... HA .......They end up on Mudders 80s one way or another.
Jason
TT
are these applicable to 70 series 24 volt 3b engineI keep these in stock. Usually never OOS.
Fusible Links - 80 Series
Toyota Land Cruiser 80 Series and LX450 1991 - 1997 New OEM Toyota parts Fusible linkwww.trail-tailor.com
Jason
TT
