Wiring Factory Fog Light Switch
hobbes
SWFL
Fresh off my successful birf job (I am single and have access to a heated garage), today I put in Slee's headlight wiring kit. Tomorrow I'm planning on the factory fog light switch + wiring. Off the fog light switch there are four wires. Two obviously connect to the Slee harness. The remaining two I assume are for lighting the switch. Flame suit on - I've searched here, SOR, and looked at the FSM. Nothing came up. There is no switch left of the steering column (US version) that is lit. What is the best method to hook up the two remaining wires to light the switch when it is enabled?
Hobbes,
It depends on the switch that you have. For example, my driving light switch doesn't have a back light that adjusts with the rheostat for the dash lights. Mine only turns on an LED with the switch is "On." The two wires in the switch that I used are for +12v and -12v. On another switch that I used (not for lights), the switch has a small lamp for lighting the switch, plus an LED that indicates the switch is "On." That one had to be wired to the dash lights which turned out to be a little trickier than I first thought.
If you got the switch from Slee then they can tell you how to wire it.
-B-
