Thanks all. Let me tell you what my problem actually was.
I found on mine that i was not getting any juice to the little electric motor that sends a surge of fluid onto my windshield.... I turned the wiper switch to the squirt position (about 3 oclock) Pushed and pulled the knob a few times, and freshend up the contacts that complete the circuit... Once this was done my lil spritzer moter was hummin like no other
Give it a shot
It was not a clog.
It was not sludge.
It was not electrical.
I first cleaned all the electrical leads. No help there.
I then checked for electrical continuity, and I got 24 Volts without a problem.
All the lines were free of debris as determined by being able to push air through all lines fairly easily.
So I decided the pump was shot and it was time to look at it.
I carefully removed the reservoir/pump assembly. It hits the brake master and I hoped it would not crack. Thank heavens it slipped out without breaking.
My sphincter puckered and my testes retracted as I gingerly tried to remove the rusted 26 year old screws holding the impeller to the reservoir. I was afraid they would rip plastic or twist their heads off. I had pre-sprayed with PB Blaster.
Screws came out and I soon had the impeller in my hand. The prop on the impeller would not turn. I sprayed with PB Blaster and turned by hand and freed it up. Still felt tight, but I decided to hit it with electricity.
Impeller whizzed like a champ!!!
I coated the screw tips with anti-seize on reassembly. Everything fit great and water tight.
I refilled with Rain-X windshield wiper fluid and all is well. I just need a shirt pin to slightly re-align the sprayers and slightly unclog the non-driver's side sprayer.
Success!!! I feel like a king, despite the fact that this was probably the simplest 1
job anyone could do. ( I managed to fight the alcoholics away Farmboy, just barely.)
Thanks one and all. Lost Marbles, the pictures were especially helpful and were much appreciated!
Best,
T
P.S. I am used to Saabs. All things Saab are complex and convoluted. This 1981 BJ-44 seems straightforward and much easier to work on. Woo Hoo!
