Wilma's Buildup thread - FJ45LV (1 Viewer)
Carolina, RI
Website
www.yankeetoys.org
Time for my build.
Specs: '64 FJ45LV, 327/3 on da tree/ no floors
What its getting:
Dontated from a 1987 FJ60, 2F, 4 speed, split case
SOA with 35's and Stazworks beadlocks
Bob Firstine's shackle reversal and saginaw box kit on order
Toybox with 4.7's is on order - 3 week wait from Marlin
Fine spline front axle with FJ80 e-locker and disk brakes, PIG inner axles and Bobby's chromo longs
Fine spline rear axle with detroit locker and disk brakes
new floors! I'll try to get close to original. I might even try to graft in the FJ60 floors I have off of the donor. But I'm not going to be picky as long as it works and doesnt look hacked.
Body protection.
SOR's seat covers and interior stuff to make it a little more cushy.
This is going to become my primary family wheeling rig. I'll be throwing a decent paint job on it and making everything work, but I'm not going to go as crazy as I had originally thought. I have one more major project going on at the shop and then I'll start in on her.
nice! looking forward to some progress pics! BTW, the 2F intake shifts the carb .75" to the drivers side compared to the F, and interferes with any chance of using the booster adapters availible... I couldnot get a booster/master combo to clear the Aisin carb...
Mike,
You might consider chopping a section out of the firewall of the 60 for the brake booster. Then use the 60 booster. Or I can hook you up with a '77 40 series firewall section/booster/pedal assembly from a parts truck in the yard...
Nick
Thanks for the info Brett, I have your PM and will study the ways of a 2F in an LV :D I'll look at the 60 to see how that'll work. If not, I'll take yo up on that Nick.
YOu using 10 spline or 19spline input gear on that toybox?
I had to take a belt sander to my output shaft on my 19spine to get it to go together correctly.. Took about 30seconds to clean it up..
I also highly recommend the heavy duty detent spring from Marlin.. Soooo worth the $.50 I spent on it!
Its going between a 4 speed and a split case out an 87 FJ60 so thats 19 spline, right?. I got the 4.7's in it too :D
ya, I just had Marlin build this one for me so it has the spring. I didnt have a top shift t case lying around so I splurged for once :) I use those in all of my mini truck dual case builds. It should be included in all kits.
you sure there's a motor underneath those spaghetti lines? :flipoff2:
i hope you plan on desmogging...you'll loose all the intestines and acually be able to show off a motor.
ROFLMAO
That was my first thought also you can only see the engine down by the block drain.
But I was polite and did not post.
:D Somehow I don't think moving that 60 to the back yard from the front yard was what the town had in mind....... :flipoff2:
That looks like the longer tail shaft H42 with the spacer?
I"m not sure if it's splined all the way up to the back of the tranny like the shorter H42 or not. But.. Here's a little tidbit I ran into on my H41 toybox. I swapped over the FJ60 top cover for an FJ40 one and the original reverse light switch was too deep and hit the adapter plate. Check that.. I think I had to use the FJ60 reverse light switch which is on all the time until you hit reverse.. Still haven't fixed that on mine..
If it's splined all the way thru then remove the spacer behind the tranny, check your clearance on the splines of the output shaft that go into Marlin's 19spline input, Put a clamp collar on the tailshaft of the tranny to keep the output shaft from walking back in and your done. For safety sake I had a 10spline clamp that had been machined by marlin which was different but I used the thickness.. Ordered the correct metric clamp collar from McMasterCarr and chucked it up in a lathe and matched the thickness of Marlins.. Don't think I needed to do that but didn't want it to interfere.
Great progress!
Mike,
If you need one of those FJ40 4-sp top covers let me know and I'll bring it to CMCC for you. I have an extra...
Gonna use that steering shaft on the "lawn ornament"? :D If not, mind bringing it to CMCC with you? Let me know on $$ or trades...
Nick
Thanks for the info.
Nick, bring it to CMCC and if I don't need it, I'll send it back to you. I'm probably not going to use the steering shaft, but I haven;t been able to free it from the firewall. Its rusted in there pretty solid. But I'll work on it with some PB and heat..
I'm allowed ONE unregisterd MV that isnt in a garage and it must be in the back yard :grinpimp:
It's getting cut up for scrap soon once I pull some more parts off of it.
Well, plans changed. Wilma now has a new owner. I have too much on my plate to start on her for atleast a year or more, so instead of letting her sit, I opted to let her go. Her new owner has similar plans and is getting the 2F/4speed/split case with her. I will get another once time allows. :D
So who wants to buy a new Toybox with 4.7's?
