Hello, I have been working on replacing a rear door lock (passenger side) for a while. I thought I was done but when I installed it in the door, that door now locks when I press unlock and unlocks when I press the lock button. All of the other doors are working properly (I didn’t replace the motors on any other door). Does anyone know where I went wrong? Thanks!
You must have purchased a replacement sourced from Australia where everything works backwards like the way the toilet flushes. Just de-pin the connector and switch position of the wires.
I thought you turned your key toward the front vs back on the front doors. I didn't think it was a matter of CCW or CW. I hope this doesn't mess with my head enough to make me go check.
Yeah i get that. Just saying i don't think it is an issue of being opposite of the doors as i think each side is different. There was no way to make the rear lock match the fronts when it comes to CW or CCW.
Ccw to unlock the tail gate
Cw to unlock the drivers side door
Ccw to unlock on pass side door here.
But my drivers side door handle doesn’t match the rest as it’s chrome and the rest are painted and it’s not keyed to the ignition and the key only works the drivers side door.
On the front doors, both left and right sides turn towards the REAR of the truck to open. This matches the direction of the actuator inside the door.
A chrome door handle indicates that handle has been replaced by the PO, as the color coded ones are not as available.
It is possible to have the lock keyed to match the passenger side (by a locksmith) which would take you back to one key (I am assuming the key is only for the door and NOT the ignition as well)
The main ignition key should fit all doors, the rear gate, and the glove box.
The "valet" key should fit everything except the glove box.
