Background first. Last winter my 2.0 starter began to 'grind' and not engage flywheel when first cranked. Immediately turn key again and everything fires up as normal. I replaced contacts hoping that would solve the problem, but it did not. We got through the winter, to the warmer weather and had no problems all summer long.
Last week was our first close to freezing temperatures. I came out of work, and winced as I turned the key because I was expecting it. Sure enough, a quick 'grind' then start just as before.
I want to know why when it is cold the starter won't fully engage flywheel on the first try?
Is there some lubricant that hardens in the cold? Should there be lubricant in the twigs and berries of the starter? Are the internal tolerances of the starter so tight that the cold creates enough friction/stiction that it doesn't work properly? If it works exactly as it should 8 months a year, why not in the 4 cold months? WHY?
I have read all the threads on the matter and maybe I am stubborn, but I can't believe that there is not a better explanation or solution (replacing the starter for a problem that only exists when it is 40 or below outside) to the issue.
How many of us have the problem, what have you pros done to fix it?
Thanks in advance for your wisdom!
