Why brake pads have two different item#s and prices?
Atlanta
Why do brake pads have two different item#s and prices for the same axle? Is the cheaper good? Is the more expensive better? What do you use?
The cheaper ones are the economy version Toyota uses for their $199 (example) per axle brake specials whenever that used to occur or maybe it still does, not sure.
I would recommend using the slightly higher priced pads if you're able to. The cheaper ones will work but they're not as good as the more expensive ones from my experience.
What difference did you notice? was it dust, noise or wear?
Quick Google shows
The economy are just the same as using the cheap auto parts brake pads. Don't use them they are not good. I have heard they make noise, create more dust, and don't last as long.
Car Care Nut did a video where he said he no longer uses the cheaper toyota pads at his shop and only the original toyota pads.
Take a look at Akebono.
Advics if you could find it. Just installed a set of rotors and pads on my wife's ES350 and really good feel and bite.
