T Y L E R said:Eric, what about the Rock Crawler wheels you see at 4Wheelparts ? They come in 16x10 with around 4" or more BS .. If I don't go spacers, I'll likely go that route. They're a steel wheel, and ring in at $72 a pc I think.
TY
wb1948 said:I put on j springs and 35s. Looked cool. Then I put 1-1/8 spacers and it looked like a beast. I didn't drive it much with out them so I can't comment on ride quality, but as far as looks... it will definately change the look of the vehicle(IMO in a good way).
Crusin said:Do I need to replace the oem studs if I put 1" spacer with the stock 16" 80's wheel?
Where can i get those spacers?
hoser said:I've run 1" spacers with OEM wheels on my 80. The OEM lug bolts will protrude slightly past the spacer but they fit right into the gaps of the OEM wheels. Does that make sense? Steering effort went up slightly but it handled just fine. The 1" spacers worked pretty good because it allowed the wheel to still make contact with the hub--keeping it hubcentric. I recommend getting a spacer that is hubcentric too.
Bear80 said:Um, the factory wheels are LUG centric so wouldn't you want a spacer that was the same? I too am thinking of using a 1" spacer for my 33's and medium setup.
T Y L E R said:Phil ,
What wheels are you running with these spacers? Width, BS etc . Do you have any pics of the 80 from the front or rear, straight on?
Thanx,
TY
Bear80 said:Well I just ordered 1" spacers. I'll post up when I get them, but I'm only running 2.5" lift and 33's. Should still look good......now to get some front mud flaps.
