Whistling sound when car cold ?
UAE
Hi guys have noticed over last couple days a whistling or whirling sound when car is cold and gets louder on acceleration then goes away after car is warm. I thought it may be my brake booster, but it's not happening on braking or start-up only when driving any idea vaccum leake etc no lights on dash showing thanks ?.
Maybe your diffs are whining a bit before your diff oil warms up. Does it sound faintly like straight cut gears in a racing tranny, only much quieter?
I had a similar problem with my 80 series. In my case it ended up being a cracked intake tube. Used electrical tape as a temporary fix.
Cheers,
Scot
Exhaust leak? Mine has a good whistle from a pin hole.
Thanks for the replys guys will check your tips today and report back.May be exhaust leake or a manifold leake.Any ideas why it goes away when car warms up.
Exhaust heats up and the metal expands to close the hole.
Thanks does it go away or always constantly.
Mine started out like yours but I never fixed it so the hole got bigger and now it whistles only between 2500-3500 rpms
Possibly the secondary air injection pump.
I had a good look today seems to be coming from around flywheel area so it may be the secondary injection pump which is under the engine cover.Anyone had experience with this.Thanks.
Thanks for the reply will it get worse and fail.
From your description (it gets loud and eventually go away when engine warms up) sounds to me like a definite SAIS.
You can read more about it this thread, tons of info:
