I prefer to use a top-brand synthetic for all fluid changes. I just dropped the transmission pan, cleaned the magnets, and replaced and refilled with Mobil 1 Synthetic ATF yesterday.
Curious, how did the magnets look and have you used the M 1 syn. before?
Would you pull the pan again?
I flushed the ATF at around 100,000. I went through about 18 qt. of M1 syn., I know wasteful, but did the job alone. I noticed a drop in MPG at that time, the trade off was smoother shifting. Will be do again this spring, when the garage warms up.
Debating if I should stick with M 1 syn or switch to the new Dexron V (GM replacement to the III). Also if I should pull the pan, which is not recommend in the FSM as a maintenance item.
Did the blue RTV hold up?It's a one-banana job, and only takes time. I would do it again just for the peace of mind KNOWING that it looked that good inside.
When I was a tech we used to call Blue RTV "back yard blue" (no offense bamachem).
I always use black RTV, especially for applications sealing oil, and Toyota black RTV is the best black RTV I've ever used. The trans pan on the 4spd will of course be sealed with their red stuff (which is also available at the dealer, along awith the black stuff).
The filter kits that I have been getting lately from Oreilly's have a rubber pan gasket included in them, which makes pulling the pan for the next person (or if you have the rig for enough miles, you) much easier the second time around, since there is no RTV cleanup.
Bawiz, you've been busy dropping five pans, messy, at-least when I've done them.
Didn't remember if it was V or VI, I pickup for flush a Chevy Van I recently did. I used Mobile, IIRC it is a blend not full syn. I had to get from wholesale distributer as no retailer carried the new Mobile AFT in Denver.
I agree the Toyota Red is great stuff.
Are the Oreilly pan gaskets giving you a 100% seal and what is the longest you've seen one on a toyota?
.....So many different numbers and fluids, Dex VI, Mercon V, T-IV, lol. Hmmm, M1 ATF isn't full synthetic? Interesting, but now that you say that, I remember hearing something about that many years ago...
To be clear Mobile 1 synthetic ATF is a full synthetic and Mobile Dexron VI is a blend. I just check with Mobile to be sure. The full syn is thicker than the Dexron VI. M 1 syn viscosity @ 100 C is 7.4 the Dexron is 5.83. Which is why (higher viscosity) I believe it reduce my MPG.
