Anyone have a shop that will press caster bushings DC area? I called Iron pig but they want 175 an hour to do it.
thanks
thanks
thanks
thanks
So I did some research and most people say to get the 20 ton over the 12 ton. I was in the store earlier and the 12 ton looked really easy to build with a couple I-beams, bolts, and a jack.
The 20 ton is welded up and more beefy.
John smith, have you found your 12 ton to be underpowered at all for automotive applications?
Maybe I'll build a shorter 40 ton press/ brake.
