I have driven LCs since 1975 and I, like many, have changed my share of tires to achieve durability, capability, image, longevity or comfort. Almost all tire talk focuses on rubbing or lifts and the assumption is usually that bigger is better. I am considering the new Nitto EXO AWT because some of my upcoming trips will be in the mountains with sharp rock and I want tougher sidewalls. BUT the Nittos may run about 65 lbs per corner. The OEM P-series Michelins are about 40. I am not talking about fuel consumption nor about ride comfort. Those are worn topics. I come from sports car racing and we always fuss with unsprung weight. The LC corners seem pretty happy with 40lb tires. I know my Tundra was not particularly good controlling heavy tires. They seems to "flop" around and you immediately felt the shock/spring setup was not controlling the inertia. So my question for those that are sensitive to corner loads and have gone to heavier tires---how did the LC suspension cope? I have been down the King custom shock road and I don't plan to move away from the stock suspension willingly. That is not a hit on King just my thinking on this truck. Also, I don't know if the factory suspension setup has changed significantly between 2007 and 2013. If it did, then I need to keep that in mind to evaluate thoughts any of you might have. I keep another set of winter only wheels and tires. I may be stuck with a third set biased as I described above. Or maybe I am not giving the LC suspension engineers enough credit. Any thoughts appreciated.
