Wheel Size / hub size? (1 Viewer)
musthave
Doc says I'm 1 in 120K. Lucky?
GOLD Star
Florida
I've read the thread here: Bolt Pattern, OEM Wheel Size, Stud Size, Hub Center Bore
Helpful, but my question is will this wheel fit? Made by Mickey Thompson. It says Hub Bore of 78.11 and from what I can tell, it needs to be 110MM.
Will this fit without issue?
Alright, so I'll go with PT960-34190-02 Toyota OEM TRD Pro wheels. They're 18", matched to 285/75/16 tires.
That lip in the center of the bore will prevent those wheels from fitting over the front hub without spacers or machining. The center bore has to be the same diameter the whole way through.
Picture 5 of 7
That lip in the center of the hub will prevent those wheels from fitting over the front hub without spacers or machining. The center bore has to be the same diameter the whole way through.
What spacer would I need to make them fit?
  • Like
Reactions: GTV
You would have to test fit the wheel on the hub, then measure the gap between the wheel mounting surfaces... then add 1/4" and that would be your spacer size. If over 1-1/2 inches, I'd abandon the idea. (1.75" if you really want them).
I was reading a thread: NEW Tundra TRD Pro forged BBS wheels
But it's 200 series thread. I wonder if anyone has installed these on a 98-07 cruiser. PT960-34190-02 is the part number of the wheel Need to figure out what spacer to order.
Ship them to my home and I will tell you what spacer is needed. ;)
