There is no service interval as they are sealed bearings. They can go 200k+ in most circumstances without any maintenance.Hello,
Surprisingly I couldn’t find anything in search. What is the FSM recommended service interval for wheel bearings?
Thanks
Mo
Yeah. I think the original question was more about regular service though. Unlike older cruisers where you'd want to repack your bearings after a stream crossing, you can't do any maintenance on our trucks.Enough go bad that they shouldn’t be ignored though. Kurt has posted about separately front and rear bearings going bad on trucks that don’t seem to be driven particularly hard.
I would not call it common, however.
Agreed, just didn’t want people to get the idea from other posts in this thread that they never have issues.Yeah. I think the original question was more about regular service though. Unlike older cruisers where you'd want to repack your bearings after a stream crossing, you can't do any maintenance on our trucks.
Are they failing more frequently than the 120/150 platform? Are those intervals stock/modified off-road?We are seeing more and more bearing issues (front and rear) as 200's get older. To be fair we don't see most of these firsthand but rather customer calling with issues and ordering parts. We offer full rear axle bearing/service kits and front axle bearing/service kits or OEM pre-assembled hub units too!
For example:
Front Hub - OEM Toyota - Fits 200 Series (FAHUB200KITOEM)
Toyota Land Cruiser Front Axle Partscruiserteq.com
I wish there was more use/mileage correlation but its kinda all over the place but generally in the 125-150k range at the earliest. On the race 200, we swap them every 1000-1500 miles![]()
I didn't see the 200-series rear axle kits on there. Not posted yet? One side is clearly bad at 160k, and considering doing the other side while I have the tools.We are seeing more and more bearing issues (front and rear) as 200's get older. To be fair we don't see most of these firsthand but rather customer calling with issues and ordering parts. We offer full rear axle bearing/service kits and front axle bearing/service kits or OEM pre-assembled hub units too!
For example:
Looks like the kit is part number RAK200SFHmmm, apparently not on there yet. We are at about 25% but popular parts should be prioritized. I’ll dig into it.
More on the kits here on Mud:
YWST: 100 & 200 Series Rear Axle Rebuild Kits
100 & 200 Series rear axles need love too! While you don't see/hear as many issues with the semi-float 100/200 Series rear axle, they are not immune to leaking seals and worn/loose outer bearings. The rear wheel bearings of the 100 & 200 Series Land Cruiser are a fair bit of work to service but...forum.ih8mud.com
In the meantime, what's the cost? Toyota/Koyo/Other bearings? I saw some of the parts were original toyota but couldn't tell for all of them.
