- Thread starter
- #21
on the topic of how wheels separate:
http://www.crashforensics.com/wheelandhubfailures.cfm
The last section deals with hub failures and their explanation for why overtightening adjusting nuts can cause failure is that it forces out the lubricant from between the bearing rollers and races and causes overheating and fatigue which in turn can lead to a full bearing lockup and hub separation.
the timken tapered bearing damage analysis and other sources had led me to believe that overtightening can also cause deformation of the bearing - but i guess that it would require waaay more than 53 ft lbs to deform the bearing components so the more likely form of failure from overtightening is tied to lack of librication by effectively squeezing it out from between the moving parts.
the reason i bring up root cause of failure by overtightening is that if you forced out the lubricant by overtightening i think you'd know by the high heat. If you deformed the bearing by overtightening (doubtful) i don't know whether you'd be looking for heat or the more likely symptom is you'd expect to hear/feel something. i imagine that (slightly) deformed parts would also translate into more heat, but even bf that you'd know by sound/feel that something's wrong?...
Sent from my iPhone using IH8MUD
