There are a couple really good wheel bearing threads that are closed, otherwise I would have posted to them. In short, I want to make sure I have attained proper preload without overtightening the adjusting nut on the wheel bearings. I am concerned b/c at the time I was working with the premise that more preload is better than loose wheel bearings, and I got to the 15lbs (on 9.5-15lb range) for the fish scale. That took more torque than I used last time and I'm sure more torque than most would be comfortable with.
For reference, here are the two threads I'm referring to that deal with proper preload on 100's and that are both closed:
https://forum.ih8mud.com/100-series-cruisers/420496-wheel-bearing-fsm-torque-light-just-right.html
https://forum.ih8mud.com/100-series-cruisers/293907-front-wheel-bearing-help-preload-question.html
The topic of proper preload is extremely important - too little or too much are both bad.
From what I'd seen on the board it seems more common for people to have loose wheel bearings so I was always more afraid of too loose than too tight. But further reading makes me realize how dangerous too much preload can be.
Problem I have is that it seems that anyone using the FSM steps end up tightening the adjusting nut a lot in order to attain the FSM spec of 9.5-15lbs using a spring tension guage (also fish scale) as described in the FSM. Alternatively they ignore FSM and use either experience or other repeatable steps to get to the proper preload (either sticking with a set torque value for the adjusting nut, or using ability to move/shift thrust washer as a guage, etc).
Checking for loose wheel bearings is easy as you can just check for play. But, how do you know if you have overtightened your bearings? The only practical way I've seen talked about is checking the temperature of the hubs?
My question is where do you take your temperature measurements from?
In the image above, I've pointed out 6 spots that I toyed with b/c they are all easily accessible without removing the wheel and they each had different temperature readings when I tested:
1) Rotor/Disc
2) Rotor where it meets the hat
3) Rotor hat
4) Edge of Hub
5) Face of Hub Flange
6) Dust Cap
I assume 1,2,3 are irrelevant b/c they are the rotor not the hub.
I figure #4 is irrelevant b/c while it's technically part of the hub, it's further away from the portion of hub that makes contact with the grease.
I think #5 and #6 are the right places to measure but wanted to know what others think and use as a guage? Also, what temperatures do others use as a guide for "too hot"?
1) Rotor/Disc
3) Rotor hat
4) Edge of Hub
6) Dust Cap
