That's the style of tool I have but have never used. It is fast and easy just to pry them back with the rotor in situ.
C-clamp the old pad against the piston. No special tool needed unless you fancy.
While searching I found this tool too but unfortunately they don't sell this in my local store; however, Napa does sell one exactly the same but with Napa brand. I believed you can use old brake pads or c-clamp and various methods without using a specific tool but I'm a newbie in this so with the proper tool will make my life easier. Thank you for all the posts/suggestions, much appreciated. This forum has helped me so much in this new adventure of mine...hopefully one day I'm good enough to give back to the community.
I came here to say this, and saw all these other answers...so I got self conscious that I maybe shouldn't do it like this....then I remembered I did this for 20 years. I overthought it.C-clamp the old pad against the piston. No special tool needed unless you fancy.
You would need to remove the caliper to use this tool, which is completely unnecessary. Same with C clamp. The front calipers are bolted to the uprights, so if you are just changing pads (not removing the rotors) there is absolutely no need to remove the caliper. You're making extra work. Even if you do need to change rotors, the prying method is quicker and easier with these front calipers.While searching I found this tool too but unfortunately they don't sell this in my local store; however, Napa does sell one exactly the same but with Napa brand. I believed you can use old brake pads or c-clamp and various methods without using a specific tool but I'm a newbie in this so with the proper tool will make my life easier. Thank you for all the posts/suggestions, much appreciated. This forum has helped me so much in this new adventure of mine...hopefully one day I'm good enough to give back to the community.
That's what I use as well....Trick question! If it's a Toyota 4 piston caliper it's most likely frozen and needs replacement anyway!
When they are not frozen, a big channellocks pliers with an old brake pad to keep the pressure even, simply holding the other two back. Doesn't take much.
