After 90'000km of severe abuse (3.8-4tons, lots of offroad use) 3 of my 4 rear pins BROKE 2 weeks ago on a bad offroad trail in middle of the Cordillera Blanca in Peru! I was VERY lucky to be able to drive down with this car again!
NOBODY has greaseable shackle pins from OME for a J75 in Peru or Bolivia! So I guess I will have some made. BUT 99% of the steel is chinese crap here!
I bought some new strong bolts (very probably made in China) and had them turn down, but without the grease hole, so it was only a temporary solution. Now that I have more time in Cusco I want 1:1 copies of the originals made with the grease hole and nipple. BUT don't know what steel I need to take.
What would you guys recommend? Can I also take spindles from older cars from the junkyard, will they be strong enough? Or 12.9 bolts? (made in China) What would you guys suggest here? I have NO idea what OME used originally... but when I removed mine the surface looked very used, I would even say up to 1mm deep grooves!
Thank you!
Thank you!
