Does the Luna charging system allow the secondary battery to contribute to starting? If it does then the cca range of a single battery isn't as important. If only one battery supplies the current for starting then you'll need a higher CCA.
If the vehicle sees use off road then you might want to consider two deep cycle batteries. High CCA typically implies thinner plates. Thin plates can handle the vibration on a paved road but they aren't good for serious off-road use. (Imagine driving on 20 miles of washboard in Utah.) I use the cheap marine deep cycle/cranking batteries from WalMart in my dual battery, 12v BJ 42. I've had them in for a year and have done many hundreds of miles in the dirt. Haven't had a single problem with them yet.
I do put all of my vehicles on a Battery Tender from once every few months for a few days. I think this helps longevity more than anything.
