I noticed a torn boot that connects the UCA to the birf. It's leaking grease. What is this part called and how easy is this to fix?
Ok, thanks. I will place a call to CDan and replace both. How easy is it to replace? Easy for you Chris does not mean easy for me..
Mxndrnks said:Craig, I have a couple of the boot rebuild kits in the garage. I don't need them and you can have them if you want. Just come get them.
...on the upper steering knuckle. Might have to do this repeatedly until the shock wave of the hammer blow separates the ball joint taper from the knuckle.Sorry to revive an old thread, but can you do this without a press? the FSM says to remove the whole control arm and then put the ball joint in a press to replace the boot. I haven't seen anyone say for sure you can do while its still installed though....
Sorry, its for the upper. piece of cake then?
