Don't mix red and green coolant. Pic one or the other and use that.
I had the green/yellow coolant when i bought my rig. Ended up flushing the system and putting in Toyota red.Should I switch to red and use that going forward? Once I switch it of course.
"...when you do mix them, then when you use any of the machines that mechanics use to see what the freeze point is, you’re going to get inaccurate readings. So if somebody tries to check to see if you have enough antifreeze in your system, so it won’t freeze in the winter for example, your reading might be wrong. If it gets really cold, you might end up cracking your engine. So basically, you’d want to stick to the coolant that the car was made for. " - soruce Mixing red and green coolant in the radiator Antifreezei don't want to come off as a smart ass but what is special about the Toyota Red antifreeze? why can't you mix it with green?
so is the Toyota red antifreeze an ethylene glycol type?"...when you do mix them, then when you use any of the machines that mechanics use to see what the freeze point is, you’re going to get inaccurate readings. So if somebody tries to check to see if you have enough antifreeze in your system, so it won’t freeze in the winter for example, your reading might be wrong. If it gets really cold, you might end up cracking your engine. So basically, you’d want to stick to the coolant that the car was made for. " - soruce Mixing red and green coolant in the radiator Antifreeze
