We just had one go bad on our 03 Tacoma shop truck which I didn't know had one until we were under it. Stiff brake pedal and not much braking as the fronts were doing all the work(rear drums on that truck). We remove them on the 80 chassis when they go under the 70 bodies....easier to add in a manual proportioning valve then to deal with brake line management since the LSPV runs a line back to the front. There are drop brackets on the 80 series when you do a lift so the bar is in the right position and works correctly.
