Yes, sort of strange question (so strange I did not know how to word it to make it make sense) and not sure whether this question really goes to 80's (since I'm specifically thinking of the weight of the rig, the typical thirty-three tires, etc), chit chat (since it is minimal tech), or outfitting (since it involves how i set my staun deflators).
Anyways, if you will excuse any misplacement, what I'm asking is what is the highest tire pressure you have had a tire bead bust at? IOW, once when running 12 to 14 psi on my runner, I busted the bead and had to switch to spare tire. But, I never busted it at 16 to 18 for example. When I did bust the bead I was sorta slipping sideways down a really smooth rock. The sidewall folded over slightly and then the bead broke from the wheel.
So, one way to ask is ... with an 80 (preferably armored and loaded) and with 33" tires (revos in this case), what would be the lowest tire pressure I could/should run at to avoid breaking a bead??? Or, IOW, and more specific to my question, if we give as many data points as possible here, we might find several who have broken beads at say 15 psi in which case I would make sure to go no lower than like 18 which is where my staun's are preset to. Instead of finding out that several people (like myself several times in the runner before the bead break incident) where lucky enough to run at such and such a pressure without a problem, I'd rather know real life examples of beads letting loose at specific pressures. Thanks.
