What is the best thing to condition my sunroof westher strip with?
Austin, TX.
I have a 2004 LC every blue moon my sunroof will leak a slight bit, usually if I open and close it once or twice that fixes the issue. Before I go replacing a bunch of stuff i want to condition the weather stripping to see if that will help.
What is the best thing to use on that rubber piece to condition it?
Thanks
go to a honda dealership and buy a tube of "shin etsu" grease
The t top mr2 guys use it with great success
Mix up some dish detergent in warm water. Wipe down the weatherstripping with a sponge or rag to clean the rubber.
After it drys wipe it down with some spray silicone. It will soak in and make the rubber softer for a better seal.
I'm pretty sure from my research in ages past that you shouldn't use silicone based products on rubber seals....
I second 303 Aerospace. I've heard good things on the German lube but have never used it personally.
I love 303 and have used it for over a decade, but it isn't as specialized as the Gummi Pflege for this application. GP was made for just this purpose and get's a strong vote.
I had a bad leak in heavy rains. I intended to replace the seal. However, I had our LX in the shop for a radiator replacement (ugh) and asked them to look at the seal. They simply thoroughly cleaned all 4 sunroof drains and now no leak. Just fyi.
Thanks for all the product information, all my roof drains are working proporely so I will put some of the 303 or PG on the seal.
Thanks again
It is a myth that silicone harms rubber. Permatex recommends their product on bushings and weatherstripping to prevent deterioration.
Shin Etsu is also a silicone grease.
But isn't silicone bad for the paint? Or is that just detailing myth? I know it's a problem in the paint booth.
Painters hate it but that is part of the prep and cleaning. I wouldn't use it if I had body work planned.
