All
What do you think I could realistically get for my 62? I am casually thinking of selling it, and taking over the wife's 4runner and buying her a more kid friendly car (just had a kid). I know that I will certainly take a "bath" on it, and have no illusions of getting stupid TLC prices. My home server is down, otherwise I would post pics again - I did post a while back.
I am sure I am missing stuff, but this is what I had in mind. I was frankly shocked how much there was after I wrote it all down! I just want a decent idea, then either commit to selling it or cross the ideal off the list.
http://www.bigspottydog.com/jack/toyo.jpg
http://www.bigspottydog.com/jack/engine1.jpg
http://www.bigspottydog.com/jack/engine2.jpg
Thanks
Jack
Here is the bio
1989 FJ62 (champaign tan)
3rd Owner with ALL receipts and records (think 4+ inches)
230k miles, all engine/transmission was done 6k ago for no real good reason other than having somthing to throw money at.
SF Bay California Car – currently located in Santa Cruz
Body is straight, no dents, never been in major accident. The rear lift gate was dented when I bought it, but got a good used one and had it painted to match (inside and out – removed all HW).
Engine
Long Block rebuilt by Clark’s machine shop (Cupertino, CA)
NEW
ALL hoses
ALL hose clamps w/ new Toyota Hose clamps
Belts
Radiator
Water Pump and Fan Clutch
EGR Valve
EGR Vacuum Modulator
Motor Mounts (Toyota)
Oil Pan
ALL Gaskets (replacement Toyota)
Fusable Link
120 Amp Alternator
Starter
Plugs/Wires/Cap/Rotor/Fuel Filter
Oil Filter (6 extra too) large old Toyota OEM
FPR
SS Battery tray w/ clamp for “standard size” battery
SS Battery tray clamp for Optima Series 31 battery
PS Pump
AC dryer
FlowMaster 60 Series Muffler
Rebuilt/Reconditioned
All injectors cleaned and balanced by RC engineering
TPS from Cruiser Parts
EGR Gas Temp
ECU from another cruiser
VSV from another cruiser
Transmission
Rebuilt A440F and Torque Converter
New Rodney (Automatic Transmission) Valve Body
New Rodney AT Temp Gauge setup
New Transmission Cooler (Plate style)
Transfer Case
TC rebuild done with ALL NEW bearings from Toyota
Replaced the PTO gear setup with the one from Australia
Suspension/Steering/Wheels
NEW
Tie Rod/Drag Link
OME Shocks and Steering stabilizer
Terrain Tamer Springs (heavy)
Anti Inversion Shackles
Greasable Pins
Poly Bushings
Rear Sway bar extensions
New Sway bar bushings (Toyota)
15x8 Rock Crawlers
32x11.5 Bridgstone ATs (3k mi)
Steering Box from another cruiser (much tighter)
Brakes
New
FJ80 MC (non-abs)
91 4Runner Calipers and Pads
TSM Rear Brake Conversion – Eldo style with e-brake
SS Brake Lines
Good E-Brake Setup with all new cables
T-100 Soft lines from body to axel
Body
ARB Front Winch Bumper
Warn Fairlead (no idea why the owner put this on without a winch)
ARB Side steps
Kaymar Rear Bumper (w/ Swing Arms mounts but no swing arm)
Tail Light Guards
Fender Flairs (Australian/Man-A-Fre) Style
Safari Snorkel – not installed
Interior
JVC Arsenal KD-SX8350 receiver (MP3 plus exterior mini-jack plug)
Front Speakers (don’t remember brand)
Rear diamond tread rubber mat
Weather Tech front mats
Nifty mounted fire extinguisher and MagLight
Dash mat (dash isn’t cracked)
Hula Dog (Golden Retriever)
Other
More spare parts than you know what to do with (all in a RubberMaid Action Packer)
A well used 1989 FSM (the good one)
A Chiltons manual good for starting a camp fire
A COMPLETE printout, sorted in a binder and in protective sleeves, of the parts microfiche
What is Wrong
Blows code 71. I think I have replaced “everything possible” – still think it is the VSV, but haven’t bought a new one. Every time I go through the FSM procedure I get stumped.
Alignment is good, but the steering wheel is a bit “off” due to steering box replacement
The front drivers spring has some inter-leaf friction and occasionally knocks when you go lock to lock without moving
Gas mileage – but you know that. 10 in town, 12 on highway, but these are estimates due to different tire sizes and lack of GPS
There was a small (and I mean small – size of eraser head) rust spot in the passenger side rear window. I scraped all the rust under the seal and the body, hit it with galvanized paint, then touch up paint.
Font axles need to be done – some seepage noticed, just haven’t done it yet
AC – I have a new drier, but there isn’t ANY Freon in the system due to a friend’s assistance during the motor removal. You will need to get it recharged.
Paint – Clear coat is fading on the rear driver side. Some scratches in the roof due to the neighbor cat getting surprised by my flip flop hitting it in the head.
What it Needs
Long Rang Gas Tank
Rear tire carrier
WINCH
Lights on the ARB bull bar
Roof Rack
CB
Thanks
Jack
Here is the bio
Engine
NEW
ALL hoses
Belts
Radiator
EGR Valve
Oil Pan
Fusable Link
120 Amp Alternator
Starter
FPR
PS Pump
AC dryer
EGR Gas Temp
Transmission
Transfer Case
NEW
Tie Rod/Drag Link
Greasable Pins
Poly Bushings
15x8 Rock Crawlers
Brakes
New
FJ80 MC (non-abs)
SS Brake Lines
Body
ARB Side steps
Tail Light Guards
Interior
Other
What is Wrong
What it Needs
Long Rang Gas Tank
Rear tire carrier
WINCH
Roof Rack
CB
