- Thread starter
- #21
I thought 1975 and earlier was the cut off year for smog equipt. in Calif????
When did it change?
When did it change?
My weber has been solid but would have gone back stock if I had to do it again. I do still have the carb and could go back that route.
X2 Mine came with a Weber and electric choke. Tis been flawless. If I had to replace it I would go back to the original Aisin.
Yep, and the Ford 2 barrel is so identical to the Holley 350 that the sealed baffle kit and chimney both fit the Ford carb. And I bet a Reman Ford is a whole lot cheaper at the parts store than a new/used/rebuilt Holley.Motorcraft 2 barrel. It'll bolt right to your Holley adapter and it works great. Plus they're a dime a dozen.
If you had a stock carb, I'd say stick with it. But since you're already converted, the Motorcraft is a great option.
Not sure if you're talking Offy/Edelbrock/Holley/Ford (everytjing above), but nuttin but a factory carb is Calif legal on a 1976-newer.did it pass Calif. smog?
how much for that set-up?
As a clear answer: the best overall carb would be a 75-77 US carb, desmogged & tuned. The 78 carb is a little smaller, so might be a limiting factor on top of an engine w/ headers.its a 1978 six cyl. with headers
It came with a Holley 2300 when I got it.
Before I spend my hard earned cash, I was wondering what you guys think works best for the buck!!
(b) During those early years, the originators of MAF were selling Rochester carbs for Landcruisers that were vented directly to the atmosphere---that DOES NOT work in off road terrain!!!
